This thread also shows how a simple solution is impossible as the people who make the rules are too clever to allow anyone to do a proper job without them telling you how.
It's all just OTT, stick a contactor in and link it to each machine and be done with it.
The trouble is Lurch, you get people getting involved who can't do it correctly.
This then results in people getting hurt, which results in rules getting made, the issue are the people who "think" that they can do it safely, but can't these then cause issues that result in regulations, and these are then law, so like it or not they must be complied with.
Don't forget, if you do something like this and it's not compliant with the law, and someone gets hurt, or worse killed, you can't insure against that.
Remember, an electrical designer was recently jailed because his safety system was not safe, and it resulted in a man being baked alive.
What makes this story so sad is it was one of the relatives of the deceased that initiated the process that killed him.
A simple solution is possible, one just has to do it right.
Don't forget machinery is "policed" by HSE, and they have a permanent warrant, that is they can enter a workplace at any time, without the requirement of a warrant from a judge, so in that aspect they have more powers then the Police.
When it goes wrong, and they sit you down in the room, the first thing that they will do, Police present or not is put you under legal caution, you know, the old "anything you say" job.
If you are putting yourself in a place where you say that you can do things like this, then you had better be able to justify that, and have the information, qualifications, experience, training and competence to back it up.
Remember also, these rules are to keep dangerous machinery out of the country, and ensure that companies in the UK can compete with others around the World who are subjected to the same rules.
This is not a global thing unfortunately though!
Canoeboy said:
In that case as they stand with no auto startup they are linked mechanically with ducting.......
That's a passive link, and you know it, it is only an active link that is an issue, and you know that too!
Any sensor of any type that sends a signal between two discrete pieces of equipment no matter which one it is "supplied from", or which one it "controls" results in them being linked.
The ducting does not send signals.
