Challenged
- Jan 27, 2021
- 3
- 0
I hope I have the correct forum here. I have a wooden shed that has been fitted out as a gym with a couple of ceiling lights and a number of double sockets. The supply comes in from the back of the shed and the cables (9mm) run in plastic trunking, currently without cable ties. What distance would you suggest I space the cable ties - I have read 25cm for horizontal and 40cm for vertical. On that basis I need to purchase 60 - but the only real length that needs "safeguarding" is just a short stretch of lighting cable that runs close to the door/escape route. The rest is either down the sides or at the back - and lets face it - the shed will burn before the cables have chance to pop out of trunking - but I know that the legislation has to be abided by. I'd appreciate your thoughts.
