When I say my customer he is a facilities manager at a company I do work for.
He had some work (cu change & a loft conversion en-suit lighting/fan + sockets in the loft conversion bedroom) done back in April 2015 took for ever to get a cert apparently.
Now he is wanting to sell & the buyers solicitor wants part P notification documents for electrical work undertaken & only having the EIC doesn't cut it.
He approaches building control to request the part P doc he should have as he was told it was registered & shows them the cert to see follow the registration number of the sparks.
"errrm can find no such company on any scheme"
Ok will the cert not enable the council to register the work under part P?
" we will not accept the cert as we can not confirm the individual or company are registered or even competent to undertake the works"
Hence I get a call from him can I undertake an EICR as BC will accept this, but only from a registered company.
Anyway without further ado here is the other fellas cert..........How long would you think this took.
(I've left his details on it as I can find no trace of such a company & the address is ...... well ....you'll have to visit every property numbered 3 in Swindon area)
If by any chance you recognise the cert Mr Taylor & you are in fact registered with a scam scheme can you please let the home owner have the correct part P documentation!
Forgot to say the supplier earth is (was) 4mm².............it is now 16mm².
