@Rob. I take on board what you are saying but the supply from DNO is beyond our scope or control.
Our remit is the Bs7671, which requires us to minimise - to reduce to the lowest factor- the effect of one circuit to another (don’t have the actual regs with me at moment, it’s on the van) therefore a dual RCD board is not reducing to the lowest factor by its very nature. ??
They mention the lowest factor, but will also have as far as reasonably practicable.
You could argue then (an I know I'm playing devils advocate here) that each point in the house should be on it's own protective device.
A duel board is the minimum requirement, but if it's all somebody can afford then it's still likely to be an improvement on what was there already. Saying it's non compliant though is not a fact.
I completely agree that boards such as the SPS board that was posted are the best way of doing things.
