Help on interpretation of the 17th edition.
mike.ses
Aug 7, 2008
The company I work for makes commercial catering equipment and we sometimes make counters incorporating sockets we normally leave the RCDs to the site electricians but we protect the various items on the counter via MCBs. In view of the 17th edition it would appear that discrimination needs to be applied and RCBOs used. Should we now make extensive use of RCBOs or should the site electricians provide the RCBOs at the distribution board incorporating all the various pieces of equipment on these counters. ?:|
Mar 7, 2008
9,994
In the office again.
You supply a fixed item. You cannot define a generic discrimination, as all installations will differ. I would agree with SlipSlap here. You, as a company, have no obligation to comply with wiring regs, UNLESS you are also in the business of connecting the units to the buyers supply??
Aug 6, 2008
32
I see no reason for you to worry about the supply of fixed units? It is for the site sparks to comply?
Obviously if you were to install an RCD spur or something for connection you job would be more than done?
In the end, when a spark buys sockets there is nothing stating it requires RCD protection etc.. He knows he has to comply with the regs and installs accordingly :) IMO
Mr Sworld
Electrical Technician
Mar 21, 2008
1,152
No. Don't worry about it.
When the items are bought and connected up by the client it will be up to them to rcd / not rcd the supply for it. If you add rcd/rcbo's to the items you will get into issues of discrimination between the in-house supply rcd's and the counter rcd.
