Haven't done one of these for a while so i thought i would take a few piccies for you all. I cant believe how small they make the torpedoes nowadays. I would use the next size up in future. Note how i did not bother to mark the cables, one being R, Y, B, BK & the other B,BK, G & BL. Since its all embedded in resin now it will never be seen again
Here's the kit
Here's the instructions
Here's the cables to be jointed. This is feeding a shed, yes its a 16mm 4 core running 3 phase. Builder cut it when the swimming pool was removed. The sheds another story. Note this years fashion in boots
The cables cut back to size
The cable couplers. Supplied with the Alan key, no torque settings but head shears when tight
The spacer thats meant to go between the cores, i did manage to get it almost in-place
The finished connections
This is the earth connector kit known as a constant pressure spring
Couple of close ups of the earth connection. Instructions say to double back under spring after 1 complete loop
Casing put on and ends taped to hold back any seepage
The two part resin, you pull a separator apart on the foil packet and need the goo together for two minutes
The finished job. You wear the supplied gloves whilst handling the resin
Here's the kit
![2011-11-01114952.jpg](https://proxy.imagearchive.com/782/782566f4d479aeff79d0bbc428080e04.jpg)
![2011-11-01115122.jpg](https://proxy.imagearchive.com/5fa/5fae5ffdf67ba915c28b9dae7b2418bf.jpg)
![2011-11-01114753.jpg](https://proxy.imagearchive.com/e3c/e3c82b10e1d59cee170244f8488575c0.jpg)
![2011-11-01120122.jpg](https://proxy.imagearchive.com/13e/13ea01e86b1aaff71c32f99b171fc19f.jpg)
![2011-11-01120948.jpg](https://proxy.imagearchive.com/fa6/fa6178bc1b67e330045e465ca62d041b.jpg)
![2011-11-01120313.jpg](https://proxy.imagearchive.com/9e9/9e9d2f215636320a56109903461bc7da.jpg)
![2011-11-01124421.jpg](https://proxy.imagearchive.com/8f0/8f088a67389ecd1738950b8068508796.jpg)
![2011-11-01115302.jpg](https://proxy.imagearchive.com/e6b/e6b27e08294cac8f5d91c654b042a39b.jpg)
![2011-11-01124138.jpg](https://proxy.imagearchive.com/407/407532f2058f10ace75aa60435e418cb.jpg)
![2011-11-01124324.jpg](https://proxy.imagearchive.com/4f6/4f6ab5860fb60680ef15895f4998c533.jpg)
![2011-11-01124750.jpg](https://proxy.imagearchive.com/c7c/c7cae56a764ba8084b62745869e7581c.jpg)
![2011-11-01124620.jpg](https://proxy.imagearchive.com/c28/c28b098a4a48ca27af2c115b902593b0.jpg)
![2011-11-01125422.jpg](https://proxy.imagearchive.com/cc3/cc3a26095a91bb16a9bcf26bb11225ea.jpg)
