Memera 2000 CU
All of them will fit in...... ]:) ; \ ;) :^O :^O
:coat
But I suppose you want em to line up on the DIN rail?????X(X( X(
Wylex are only 1mm or 2mm shorter, but otherwise holes & bits appear to line up ok.
You may get away with it?
what size are you after? :| ?:|
I've been through my boxes of MCB's and none of them line up, the closest that I can get is a Siemens MCB, the holes line up, but the switch leaves a gap that I don't like between it and the cover (it doesn't come forward enough!!)
ummm:(
I was just clicking some bits on a DIN rail here.....
got no enclosures/covers to check with...
as you say the Wylex is approx 3mm or 4mm shorter on the "forward projection"! :|
what about the old favourite link...
http://www.thefusecompany.com/fuse.php?***th=68&products_id=709
or
http://www.thefusecompany.com/fuse.php?***th=68&products_id=731
Nick, This guy , in Birmingham, by Spaghetti Junction , sells new and refurbed fuses/MCBs/RCBO/MCCBs. I don't know if he would post stuff like MCBs, can't see why not TBH. Could be useful if you were stuck.
The name is Current , blokes name is Bob , 0121 328 3343 Fax 0121 328 5008
Deke
