My supplier has told me my meter installation is illegal, how do I rectify ?
benawhile
Jun 6, 2023
9
Basingstoke, UK
While in communication with my electricity provider, Octopus, about fitting a smartmeter, and providing photographs, I have been told that my electric meter has been illegally boxed in. The kitchen was professionally fitted 4 years ago.
Please could you advise the minimum I need to do to make it legal again as I wish to have a smart meter installed, as I am concerned that the current meter may be expired and unsafe.
The shelf that obstructs access is currently easily removable, it rests on a few removable pegs.
How far do I need to cut back the backboard?
Do I need to improve access to the first connection from the mains input as well?
We had the house upgraded and the builders insisted on dot and dab all over the kitchen, after the rewiring and new distribution board, with a very ugly result as you can see, so the kitchen fitter was left with little option.
    1.3 MB
    1.2 MB
    912.3 KB
    1.3 MB
    1.5 MB
    2.8 MB
There is no easy way to say this.
Both your builder and your kitchen fitter are idiots. There is no way either of them should have boxed in the supply head and meter like that.
The resolution is remove a big chunk of the kitchen, rip out the sections of the wall that are in the way, pay the supply company to move the supply head and meter to a location that is going to remain accessible, and then rebuild it.
If you had the meter and supply head moved FIRST you would not be in this painful position. Shame you did not ask here first before any of this boxing in happened.
By the looks of the location of the meter the whole cupboard would need removing out of that section in order to not restrict access for changing the meter it already looks like a new ish meter so not sure why you want it changing but it's not in a particular good place for metering personell and DNO personell to work on
looks to me that most of the backboard and all the right hand wall of the cupboard, then the base will be unstable, this may have to removed as well, they will need access to the MET and natural terminal at the head,
PS, don't forget both doors ,
you should have done what Dave said, and got the meter and head moved to outside ( the other side of the wall) to late now?
I've had an email from Octopus/Coop saying the meter is past its certification date. Could they be mistaken as you say it looks "Newish"?
What are DNO personnel?
The meter has been in that location since 1955. Before the fitted unit there was a deep worktop space over it so access was always restricted.
None of that is professionally fitted!!
A professional trades person will be well aware that as well as installing items, fittings, accessories etc....
that you need to take account of access for future maintenance, replacement not just daily usage..!
From my experience this type of work is normally done by the rip-off cowboy merchants, who do cheap, poor quality work but charge the customer well over what is a reasonable price for their poor design..
Is that one hole in the back-board the stop-tap...?
Goodness knows what you will do if that gets seized up or starts leaking and you need to replace it? !
All electrical joints should be accessible for inspection, testing, remedial work or replacement. etc..
So you NEVER box them all in like yours has been!
On your first photo towards the bottom right had corner of the far wall you can see the the incoming supply cable going into the main cut-out fuse, then the tails from the cut out to the electric meter all mounted on the suppliers back-board..
I would suggest that the whole of that back board down to floor level should be made accessible by cutting sections of the cabinet out.. Then a good carpenter may be able to make some dummy cabinet back wall, inner side walls, and shelf inserts that can all be completely removed when access is needed..
Either the whole of that base unit should have been designed as movable,
or the meter should have been moved before it was buried by "Bodgit & Scarper Ltd"..
That design is about as useful as a car with the bonnet welded shut..
but a couple of holes to see the oil and water top-up points!!
Don't worry about how to say it Dave just let it rip!! The house was passed by building regs, albeit before the fitted cupboards. THis is the standard you get here in Basingstoke. We had lots of trouble with builders and nearly went bankrupt, ended in court and now we are climbing out of the hole.
So what I want is solutions. I can't remove any walls. If the only way is to pay to put the meter outside I will do that but would rather not. If nec I can cut out most of the back board, but what do the regs actually say about accessibility?
You say if I had moved the meter FIRST? I don't understand this, I am not moving the meter. Or do you mean if I had moved it outside before the fitted kitchen? Agree with that.
DNO - District Network Operator, ie the people responsible for running the mains network.
Its not an unusual problem, but kitchen fitters dont tend to give a damn! What should have happened was contacting DNO to relocate the consumer head (thats the main cut out fuse), probably to an external wall box, or possibly an attached garage. The mains fuse board (or consumer unit as we call them these days) should also have been relocated, and yes that would have cost extra. The other option would have been to design the kitchen to allow suitable access, but I've never found that to be 'satisfactory' in reality.
OK. Well I will start by going back to Octopus customer service tomorrow. All they said up till now is that their engineer will take one look at the installation and go home. That's all very well and very dramatic, but I need to talk to that engineer and ask them exactly what needs to be done to make replacement possible.
The actual wording of the regs is not the issue..
The problem you have is just basic common sense, that there must be enough space for an average sized adult to access any equipment, to undertake any repair , testing, alteration works on that equipment in a safe manner.
There is no way in a million years the DNO can access their equipment, nor could a plumber access the stop-tap..!!
Its not rocket science.... (Unless you are a professional kitchen fitter who just finds it all too complicated! )
I cannot see how you could move the meter now without cutting the back of the cupboard anyway!!!
You are stuck with what you have, and unless you want to remove the whole corner unit you need to modify the insides!
From your pictures I would guess that with the doors off, and shelves out, a section of the back, (maybe a bit of floor as well) removed, I could kneel in their to access the meter / cut out without too much difficulty?
Not much worse than some under-stairs cupboards that still have meters inside them!
With a modern day oscillating mutli-tool saw, I could cut enough sections out, and with a few wood battens & some white melamine boards I would be able to cobble together some removable patched up interior sections....
much better access than you currently have..
But as I said earlier a good carpenter would do an even better job!
Special Location, That is more specific, thanks. The meter and cut out unit are sunk not only into the back board but behind that also into the dry lining dot and dab. When the Leccy replaced the consumer unit and fixed it onto the original solid interior wall he wasn't told that afterward it would be surrounded in dot and dab. So as well as the back board I have to cut out the dot and dab so that an electrician can access the whole depth of the meter up to where it meets the solid wall it is mounted on. I will then have to seal the gaps between the plasterboard and solid wall with foam, as there seems to be a cold draught behind the plasterboard.
Moving the meter outside would be a better job but looks like may cost a grand altogether, I have to decide.
It gets worse.
So the builder has created a "plasterboard tent". He has just lined the inside of an old house with plasterboard, with no insulation, no sealing of voids so as you have noted, cold outside air is free to circulate between the walls of the house and the plasterboard tent. I bet your house is cold and costs a fortune to heat.
You need access to YOUR consumer unit as well.
It might be possible to move the supply head and meter to an outside meter box, or it might be possible just to move them higher up the wall where they can be incorporated into a proper sized cupboard with proper access.
Like i say there is no easy or quick solution, I think that corner kitchen unit and the worktop above it has to come out at the very least to give access to cut a BIG hole in the plasterboard, relocate the supply head, meter and possibly your consumer unit, then see if it can be all put back together with the kitchen as you want it.
I am particularly disappointed in your electrician for not pointing out to you the troubles that lie ahead leaving the meter and supply head where it was.
This kitchen installation is a perfect demonstration of the lack regard other trades have when it comes to access to electrical equipment and other things like stop taps
As mentioned previously the way the holes around the meter and service head have been cut looks very amateur although it does look better than some kitchen fitters work I have seen in the last few years
Please don’t refer to them as Engineers. At best they are meter fitters. My daughters friend is one, her previous job was as a Pole Dancer
As Kerching points out....
There is a vast army of semi skilled Meter-Monkeys.. who's only job, skill, training, is to replace an easily accessible meter with another newer meter!
With little or NO electrical qualifications...
And absolutely ZERO experience to modify a cabinet......
Write your reply...
