Whilst 2nd fixing an extension customer has asked if I can add a phone point in new bedroom
I can drop a cable in no problem but getting back to master socket is a nightmare, other side of house @10m new tiling above, laminate everywhere else up&down
however I've noticed that there is a plug in extension from master in hall to living room
I think I've found this far end of bedroom (goes up hall wall, behind coving 4m then under laminated landing, under tiled bathroom until it crosses corner of bedroom then down wall to living room)
My questions are
can I cut this cable and joint in my new cable so the plug in extension serves both slave sockets?
Will it work correctly?
I'm assuming il still only need to connect pin 2.& 5.
My questions are
