yes Class two / Double insulated, the same thing
Yes it does state double insulated I wonder if it has the symbol on it.yes Class two / Double insulated, the same thing
I would not use metal screws, I would use Nylon ones, https://www.deligo.co.uk/Products/m35-screw-nylon/BPNN35 in to a metal boxonce you fit the metal screws face plate screws.
That is a very odd statementIf its not got an earth terminal its class 2
Lack of an earth terminal does not mean Class II especially once you fit the metal screws face plate screws.
You probably need to have a look at what Class II insulation actually means.just use the screw covers provided.
Class II requires knowledge of its application and suggesting plastic caps over cover screws suggest you don't have it.theres no point in discussing this with you any more
common sense and a pragmatic approach …
Not sure what you are getting at, the box would be deemed an enclosure caps or not.Plastic caps over screws require a tool to remove then, does this then class the box as an enclosure? rhetorical question
